Sitemap.xml Showing Old Domain URLs on Smart Degree Hub
https://smartdegreehub.page.gd/
Google Search Console shows “Couldn’t fetch” and “Sitemap could not be read” for https://smartdegreehub.page.gd/sitemap.xml.
My website is smartdegreehub.page.gd.
Google Search Console shows “Couldn’t fetch” and “Sitemap could not be read” for my sitemap.
The file htdocs/sitemap.xml contains the correct domain, but opening the normal sitemap URL sometimes shows old yourdomain.in URLs in View Source. Opening it with a query string shows the correct domain.
There is only one sitemap.xml file in htdocs. Please help check why the server returns different content for the normal URL.
I can’t find anything on the forum that explains the normal URL serving different content from the same file. So I need a bit more to narrow it down.
Can you open https://smartdegreehub.page.gd/sitemap.xml in a private browser window, or on another device or network? Then tell me whether View Source still shows the yourdomain.in URLs. If it only happens in your normal browser, it’s most likely a cached copy on your side and not the server. If it shows up everywhere, that’s a different problem. Also, is the htdocs/sitemap.xml you checked the one you see in the file manager or FTP, and when did you last change it?
On the “Couldn’t fetch” part, InfinityFree puts a browser check in front of every free site. It needs JavaScript and cookies, so validators and command-line tools often fail on it. The article on it says Google and the other major search engines are fine with it, so I wouldn’t assume that check is your cause:
Google may also still be holding a failed fetch from when the file had the wrong domain in it. Once the first question is settled, that will be easier to judge.
I checked the sitemap in a Chrome Incognito window. View Source shows the correct smartdegreehub.page.gd URLs there. I checked the htdocs/sitemap.xml file in the InfinityFree File Manager, and it contains the correct domain too. I last edited the sitemap on 12 October 2026.
Google Search Console still reports “Couldn’t fetch” and “Sitemap could not be read”. Could you advise what to check next?
hello can you help me
Google will not immediately pick up the changes you’ve made. “Still reports” and it’s most likely that Google didn’t bother to check your website again, so please give it sometime. As if how long it will be, we cannot tell since we are not Google.
Also the bot only make a single reply. It will not follow up.
It’s probably nothing. The checker in Search Console and the actual Google crawler work separately from each other. We have a security system that blocks most non-browser access to websites on our hosting, and have made precautions to ensure that the Google search crawler can go through but the search console checker might not.
