moviemlwbd.epizy.com
when i type https://moviemlwbd.epizy.com/sitemap.xml in url box it’s showing page not found.
page 404 not found..
That means you never uploaded the file. Make sure the file is names correctly, and uploaded to your sites root folder.
how to upload pls tell me…im new…
Oxy
April 27, 2023, 6:59am
6
as far as I can see, your site uses the Y. plugin
and then does a redirect where it serves sitemaps
depending on the user agent (recognizing search bots)
but the problem is that the hosting adds this ?i=1 to the end if you visit the link directly
https://moviemlwbd.epizy.com/sitemap.xml?i=1
and then there is no redirection
when you manually delete ?i=1 and visit (assuming you have a stored __test cookie) then you will see a redirect
