Sitemap Could not be read
I have created a sitemap but when I checked the sitemap it gave an error, the response was not xml but html/txt, that’s probably what caused the Google Search Console Error list, Problem detected, please check details below Sitemap URL https://olengbloge.my.id/sitemap.xml Character Set Sitemap is valid No Warnings - Errors Incorrect http header content-type: “text/html” (expected: “application/xml”) the error is like that, please help, your help means a lot. thank you
Link sitemap : https://olengbloge.my.id/sitemap.xml
This is due to the secuirity system of InfinityFree.
In addition to what @EuropeanRat said earlier:
The security challenge is also presented as HTML content, which may explain the content type. - Admin
It because your sitemap is not a sitemap, it’s a text file. You need a sitemap in proper XML form for it to work correct. This could be a side effect of the browser system, but from my side it looks like in incorrect file. Can you share a screenshot of the actual file on your computer?
