Site not responding
(luthercompaore.iblogger.org)
(ERR_CONNECTION_TIMED_OUT)
(Hi, I need some help with my website. I can’t access to my site or even the admin dashboard from my PC when I connect normally. However, both work perfectly when I use a VPN. This makes me think my IP address or my connection might be blocked somewhere. Could you please check what could be causing this issue?)
Hello, and Welcome to the InfinityFree Forum @Justanotheruser!
Working fine on my end.
If your site is new, you may have to wait up to 72 hours to resolve on your end. This is due to DNS caching/propagation.
If your site is not new, there could be 2 things going on:
  1. Your ISP is blocking the connection. They could have blocked the main domain iblogger.org as a bad site. You will have to contact your ISP to resolve this issue.
    If they say that iblogger.org and/or luthercompaore.iblogger.org is not blocked, it could be:
  2. Our Abuse Detection/Prevention Systems may have flagged and blocked your IP address, causing this issue. This doesn’t happen often, but when it does it produces a similar result. Our Admin will have to send your IP address upstream to the Abuse Management Team (over at iFastNet) to see if this is the case.
Thank you so much for the help.
