Hello, I have a problem: I recently started using InfinityFree, but my website is unreachable (there is just a dummy site with ads). Interesting thing though, when i use “www.” before my domain, it works! I tried to redirect it with a htaccess rule, that didn’t work.
Update: It seems to work now. Maybe an old DNS-Cache.
No, it still only shows this “Bodis” site. Anyone else having the problem?
I see this instead:
This is most likely the result of either incomplete DNS propagation, or DNS cache. Take a look at the following article.
Admittedly however I’m not sure why it worked for you once and then stopped, unless you were using a different network or device at the time.
I was indeed using a different device + VPN at the time it worked. Sorry for the misunderstandings!
Hm. It seems like there is a difference between the bonlando.rf.gd and the www.bonlando.rf.gd sites. I just installed the SSL certificate and it seems to work for the “www.” site, but not for the normal one. And still, I see the Bodis advertisements on the normal site, but my “www.” site works. Although I made sure that both of them link to the same IP:
| Domain | Type | Target | Actions |
| bonlando.rf.gd | A | 185.27.134.176 | |
| www.bonlando.rf.gd | A | 185.27.134.176 |
Any ideas?
Both work fine for me and have valid SSL.
This probably still applies:
