Site not loading
Iv Just tried to look at my site and it’s not loading, it’s saying ‘This site can’t be reached’
http://mymedicalfiles.uk/index.htm
I’m new to this so not sure what’s needed for it to show again
The ns.epizy.com nameservers aren’t working. Please check this forum for more information and use the byet[.]org nameservers.
It looks like your domain name isn’t delegated to any nameservers at this time: Dig web interface - online dns lookup tool
The WHOIS information shows that you’ve configured the nameservers correctly, but it also shows this line:
Data validation:
Nominet was not able to match the registrant’s name and/or address against a 3rd party source on 06-Mar-2019
As well as:
*** This registration has been SUSPENDED. ***
So it looks like your domain name was taken down by the registry because you didn’t verify your details. I don’t know enough about .uk domains to tell you how or where to fix this, but I know that your domain provider should be able to tell you that.
Thanks for replies, i’v changed name servers and checked with the company I bought the domain from and everything seems to be set ok. It’s not been suspended with them so not sure what the issue is
It looks like the suspension was lifted because the domain is working from here now. If it doesn’t yet work for you, that’s likely due to DNS propagation, which you can work around using the instructions in this article: https://infinityfree.net/support/why-doesnt-my-domain-work/
