Site loading slow + problems with File Manager
epiz_29141432
http://revenue-ads.online/
Site loading slow + problems with File Manager. +Timed Out (Sometimes) + Bad Gateways (Sometimes)
I want someone from the staff member to solve the problem for me. There are many problems, the File Manager did not open (Sometimes), and the problems in loading the site. This does not make me happy or my visitors happy.
File Manager Error: https://blogger.googleusercontent.com/img/a/AVvXsEgUehfswjUFghl0rIDDfmrUFNzcj4O7Cl1bpspARmwFlC2-r3ZY13OMs1ztwGOuBctNfTsu8vMXi5KNtXmRjTBAXESU-Kkh1bF-hbSk0BK3eUmZzF6gMkabzTq60vDt7aYfqi1rMigRKTtXk2ioDNy9RMfUghOyC2_avEs284fSP2FU1NVocQ-3tcCx=s16000
And Solve my website loading error + Bad Gateway (Sometimes). → the problem is from the host.
Kind Regards
Your site loads fast and fine for me.
Welcome to the forum @anon62321878!
Your site load in .34 seconds for me, so if you are having issues, I recommend you try clearing your cache.
As for the file manager, please try downloading the desktop FTP software FileZilla.
Please let me know if you have any questions!
Your website is working fine, you should take advice from @Greenreader9 and I also don’t see any error in the screenshot you posted.
Site design is more important for fast load!
I think your site is desktop friendly but not mobile friendly!
So try to fix codes for mobile version then check the performance!
This problem happens to me sometimes, and not just with me also my friends.
This should help solve that:
Did you check your code for errors? I sus that.
Ok, thanks
