Sir SMTP php mails like this no-reply@localshost mails are not be able to send
Yes, mail()
is blocked here, please use a smtp server with PHPMailer in your code.
Can yo recommend me the domain or site from where I can buy domain with SMTP enabled
I use Mailazy, it has a free plan. You can also use SendGrid, SendInBlue.
Thanks bro
Gmail.com, works as well
Sir can you tell how to setup mailazy
Sir is there any video for help
Please use Google to ask these questions, as they are ones that can be answered faster that way.
https://youtube.com/results?sp=mAEA&search_query=Mailazy.com+setup+smtp
Sir can I use any SQL database rather than on your website on my site
You can connect to a MySQL database hosted elsewhere from your website hosted here.
However, please do keep in mind that database connections are quite sensitive to latency. Our databases servers are located very close to the websites, which means connections are very fast. If you use a database hosted elsewhere, latency will be much higher, which will likely hurt the performance of your site.
