Setting up Freenom domain
I had purchased the domain from freenom and added it to parked domain section on infinityfree client area and had changed the nameservers (as seen in the image below)
and has requested ssl certificate for my domain from infinityfree Free SSL Certificate section but now the problem is that on infinityfree it says me add some CNAME record to my domain in order to approve SSL Certificate request, but when I am changing my CNAME record in Freenom it forces me to change my nameservers to default freenom nameservers
ns01.freenom.com
ns02.freenom.com
ns03.freenom.com
ns04.freenom.com
ns05.freenom.com
You have to change your CNAME records in InfinityFree, not in Freenom because you pointed your nameservers to InfinityFree. I hope this helps! :slightly_smiling_face:
Your nameservers are definitely wrong! You shd follow instructions here…
Shd be done within VPanel
Ok thanks for letting me know
