Hello, i create the an account, i use register.it for register my domain, i have change the dns but nothing appen, what dns i should use?
You are limited by this
Yes i have already did, i need to know if is possible the correct dns nameserver and ip so i can check
Please read the article that @KangJL posted. If you’ve read it, and you understand what it says, you know the answer on what you can do to solve this.
As the article mentions, if your domain’s TLD is one of the following, nothing can be done:
If your domain extension is not one of those, then you may be lucky, as all you have to do is disable DNSSEC on your domain. Your registrar should be able to help you with that.
