Secure Connection Failed An error occurred during a connection to virbooth.likesyou.org. Peer repo
https://virbooth.likesyou.org/
Hello InfinityFree Support,
I am experiencing an SSL/TLS problem with my free subdomain:
The website works normally over HTTP:
http://virbooth.likesyou.org
However, HTTPS is currently not working:
Firefox shows the following error:
SSL_ERROR_INTERNAL_ERROR_ALERT
The SSL/TLS manager says:
“This appears to be a subdomain. Subdomains have SSL automatically enabled. To access please use https://virbooth.likesyou.org without www.”
HTTPS was working previously, but suddenly stopped working. I have not intentionally changed the SSL configuration.
Could you please check whether the SSL certificate/TLS configuration for virbooth.likesyou.org is active and working correctly on your server?
Please also check whether there is any issue with the automatic SSL for the free subdomain.
Thank you.
Virbooth.likesyou.org
My website is inaccessible and shows an ERR_SSL_PROTOCOL_ERROR; could you please help check it? Thank you.
a subdomain can share an SSL certificate with the root domain, i think there is an SSL certificate issue with the domain likesyou.org
Actually, there is no SSL certificate on the root domain. “likesyou.org” is a common reseller domain for all mofh clients, iFastNet can only fix this as far as I know. Wait till Admin Shows up
There is no correct SSL certificate on the root domain “likesyou.org”.
Just to let you know, the issue has been fixed some time yesterday. Your website is fully operational again on HTTPS!
