Script scheme.org for free users
https://plusevo.xo.je
no custom script
free users cannot get following like this one ?
{script type=“application/ld+json”} { “@context”: “https://schema.org”, “@type”: “Organization”, “name”: â€œćˆćŒäŒšç€Ÿăƒ—ăƒ©ă‚čスボăƒȘăƒ„ăƒŒă‚·ăƒ§ăƒłâ€, “alternateName”: “plusevo,LLC”, “url”: “https://plusevo.xo.je”,
{/script}
You can use php, JavaScript, and html
Not sure what the script you’re trying to run is though
php with *** as ok ?
Usually, I’m using Site.pro as default
Right. A lot of site pro features are locked behind their paid subscription.
That’s a decision made by site.pro not infinity free
Ok,I see. Let me try to call an include and hard write it.
Thank you. :slight_smile:
I strongly recommend against messing with the Site.Pro generated code. It’s not meant to be hand-edited. If you need more flexibility than Site.Pro provides, your best bet is to switch to a different way to build a website.
Also, FYI: even if you do manage to get the schema.org data set up, it probably still won’t work because automated access to websites on our hosting is blocked.
So, Any solution for scheme.org with sitePro ?
{meta name=“robots” content=“index, follow”}
this one is effective or not ?
Why site.pro do not mind any SEO solution ?
For site.pro specific issues you may be better asking them FAQ | Professional Website Builder for Your Business - Site.pro
Since it’s an external service we don’t always have all the answers.
Although I think admin’s answer was quite clear:
even if you can get the data in the site.pro editor, it’s likely it wont work the way you’re expecting it to
Under the Settings → Settings menu, there is an option Meta Tags. I haven’t used it myself, but maybe you can add the schema.org data there? The tags are side wide, not page specific, but the example you gave showed an Organization entity, so side wide might be enough for you.
But a fundamental problem with any website building software is that the options it provides is finite. Some software is very extensible so you can get quite far, but managed website builders like Site.Pro typically favor ease of use over versatility. And if Site.Pro doesn’t have certain functionality, it means you cannot use that functionality on a site built with Site.Pro.
