Script installer
https://animefull.rf.gd
It’s my first time here on forum
and i am wondering what the script installer is ? and what it uses for ?
  • i am not yet finished my site i am working on Google ads
i just wanna know what the script installer is and how i can use it + if anyone have a video tutorial that would be helpful.
Welcome to the forum
best advice I can offer is have a play and see haha
but seriously, the script installer just lets you install from a range of pre-configured scripts (like wordpress). It just makes installation of some tools quicker and easier
i would but i already uploaded the site u k i don’t wanna take the risk ,
if there any video or tutorial so i can understand better would help a lot.
thx man for sharing .
Not that I’m aware of. But honestly, you can look at the script installer without installing a script. Or you can set up a second domain and try installing scripts on that.
Just wanted to check. I’ve looked at your site, and it looks like you might be sharing a pirated anime? Just so you’re aware, this goes against the terms of service, and if you’re caught the site will be suspended without warning. If I’m wrong I’m sorry for jumping to conclusions. Its just the option to download onepice seems… questionable.
Looking inside the script installer is completely safe. Nothing will be installed unless you specifically hit the button to install a site. And if the script installer detects that it might overwrite files of your website, it will stop and ask you to confirm.
In other words, you can safely have a peek. If you pay a little bit of attention to what you are doing, there is no risk to accidentally overwrite your website.
You can also have a look at the official Softaculous demo to see what it looks like. You can view it here: Softaculous
