Same Wordpress website for 2 domains
I started off by creating an InfinityFree domain and installed wordpress to this domain. I finished my website and all was looking good.
I then added my personal domain to my InfinityFree account so now I have 2 domains under my account.
I then set up my personal domain to use the InfinityFree nameservers.
All good so far.
In Wordpress, I then proceeded to change the following setting
WordPress Address (URL) : http://www.carolinedai.infy.uk
Site Address (URL) : http://www.carolinedai.co.uk
The result was that both domains show the same Wordpress website.
I then installed SSL to both domains and then things started falling apart.
In Wordpress, I change the “http” to “https” in the above setting but that did not work.
I had to set the Site Address to be the same as the Wordpress Address (InfinityFree domain) to restore normality.
As a result, my personal domain does not work correctly anymore.
Can anyone provide some guidance on how I can get my personal domain working ? I don’t mind if the InfinityFree domain goes down.
Thank you in advance.
Please understand that WordPress does not support this. WordPress is intended to host a single website on a single domain name.
Your website appears to be configured to be hosted on https://www.carolinedai.infy.uk/. So that URL works. But it’s not configured to work on http://www.carolinedai.co.uk/, so that URL does not work correctly.
If you want to keep using WordPress, I think you’ll need to do the following:
  1. Choose whether your website is hosted on the free subdomain or the custom domain (you can choose only one!).
  2. Configure the website URL in WordPress to use this domain name.
  3. Setup a redirect from the domain you didn’t choose to your new domain name, to ensure no traffic is lost.
We can probably give you more specific instructions if we know more about exactly what you need to do. Also, can you please tell us the Directory on your account that both domains are linked to?
Hi Infinity team,
Many thanks for the quick response. I think I understand the situation now.
  1. I would like the website to be hosted on my custom domain
  2. Setup re-direct for the unused domain.
Can someone provide specific instructions on how to do this ?
The directory on the account for both domains is in “htdocs” ? Is this what you are asking for ?
I am very new at this … so learning a lot here.
Many thanks !
Thank you for the additional information.
In that case, I would do the following:
  1. Login to the WordPress admin interface at http://www.carolinedai.infy.uk/wp-admin/, go to Settings → General and replace carolinedai.infy.uk with carolinedai.co.uk everywhere.
  2. Verify that your website now works correctly on https://www.carolinedai.co.uk/.
  3. Remove the domain carolinedai.infy.uk from your account and add it again.
    • This will make it so that the subdomain will not be linked to the main htdocs directory, but to a separate directory carolinedai.infy.uk/htdocs. This enables you to configure a redirect that only applies to the subdomain, but not your new domain.
  4. Use the Redirects tool in the client area to setup a redirect for your subdomain to redirect it to your custom domain.
When you have completed these steps, WordPress should be fully functional on your new domain and your subdomain will redirect all visitors to it.
Hi Admin team,
Many thanks for showing me the ropes. I followed these instructions and now everything is working as you described.
Best wishes
harpoon
