Resource usage warning on 0 traffic site
Hi, I have a problem with my hosting for atsibusk.lt
I get emails:
Hello Valued Customer,
This mail is to inform you that your site with the username epiz_xxxx has utilised over 50% of its daily resource limits.
This limit is reset every day.
The resources that your site has used over 50% on is :
io warning
My website literally gets like half a visitor per day on average, I haven’t updated the website in months and I keep getting these emails. How do I (or you) fix this?
Please note that plugins, (Especially backup plugins), and visitors (Including bots) can cause that. Since you are getting it repeatedly, i’m going to guess that a plugin is at fault.
As @Greenreader9 said:
About the bots you should probably see:
