IMPACT: The control panel at cpanel.infinityfree.com is down. FTP and file manager access is not enabled automatically for new accounts. AFFECTED: All accounts are affected. STATUS: Resolved. NEXT UPDATE: None.
WORKAROUND: You can use https://cpanel.epizy.com as an alternative. LAST UPDATED: 2025-11-14 12:45 UTC
Please keep all discussion in this topic. New topics about this issue will be closed.
Only post if your issue matches what’s described above.
Different error or component? Create a new support topic instead!
Include your website URL when posting in case we need to check something.
Don’t post “me too” messages - we know there is an issue affecting you.
I’m experiencing the same issue.
Both dash.infinityfree.com and cpanel.infinityfree.com redirect to HTTPS and show ERR_SSL_PROTOCOL_ERROR, so it looks like the iFastNet control panel SSL/system is down globally.
As a temporary workaround, I can still log in using the vPanel URL:
The client area itself is accessible (and has been during this outage), but some functionality will not work. I’m implementing a workaround in the client area that should fix the client area functionality.
Yes, the workaround was released roughly half an hour after I wrote that message. All client area functionality is working again!
One issue I noticed though for new hosting accounts: you will need to login manually to https://cpanel.epizy.com with your hosting account details to enable FTP and file manager access. Normally this happens automatically behind the scenes, but due to the the control panel being difficult to access is this not working right now.
