Request for Assistance with HTTPS Request and SSL Certification Error
Hi,
I hope this message finds you well. I am currently encountering an issue while trying to make an HTTPS request to retrieve my data from the server. The request results in the following HTML error message:
<html><body><script type="text/javascript" src="/aes.js" ></script><script>function toNumbers(d){var e=[];d.replace(/(..)/g,function(d){e.push(parseInt(d,16))});return e}function toHex(){for(var d=[],d=1==arguments.length&&arguments[0].constructor==Array?arguments[0]:arguments,e="",f=0;f<d.length;f++)e+=(16>d[f]?"0":"")+d[f].toString(16);return e.toLowerCase()}var a=toNumbers("f655ba9d09a112d4968c63579db590b4"),b=toNumbers("98344c2eee86c3994890592585b49f80"),c=toNu
Additionally, when I attempt to execute my Python code for the same request, I receive an error stating:
requests.exceptions.SSLError: HTTPSConnectionPool(host='arenatest.42web.io', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1000)')))
It seems that there may be an issue related to SSL certificate verification. I would greatly appreciate your guidance on how to resolve this issue, as I am unsure of the next steps to take.
Thank you in advance for your help!
(Request for Assistance with HTTPS Request and SSL Certification Error)
Please read:
Read this
