i got an ssl certificate and want to use the secure version , it works fine , however , the https version still available and have same files as the secured one .
can i remove the unsecure one ?
Write clearly.
Most likely you are referring to this
From where?
Instead of changing in http to https in file code use force https without touching the code that will help to avoid issue when SSL broken
