Good evening, I would like to know something about FTP accounts, knowing that I use the free service of infinityFree I would like to know if I can for example connect to the server via a python script or other that has no relation to the site that I host, and which is only for me for testing purposes, and therefore manipulate files, add, remove etc…
If you do not understand very well, let me know and I will give you a concrete example.
WB !
It can be a browser, program, IDE, etc…
If you have a problem - try to enter the IP ( 185.27.134.11) instead of ftpupload.net for the server/host, check AV and FW that they are not blocking the app/script
But I must warn you that connections to the FTP server are monitored
as well as the files that are uploaded and the number of connections during the day, so if it is noticed that someone is using the FTP server for automated
actions and uploading, for example, images from the surveillance camera every now and then, do not be surprised if FTP access is disabled for you for a while or maybe a permanent suspension.
For some reasonable testing I see no reason why that would be a problem.
