You don’t have permission to access /panel/indexpl.php on this server.
when i try to redirect my website to any other website or subdomain it shows this error, the issue i am having is with ssl i installed the ssl certificate it works perfectly but when i type my website in the search bar : ‘renderoot,uk’ (without the https) it does not work it shows that my website is over http, when i search for my website in google it shows the same issue, i have to manually write ‘https;//renderoot,uk’ in order to work so i thought to redirect ‘http;//renderoot,uk’ to ‘https;//renderoot,uk’ to solve the problem but i got another problem wich is this error message : You don’t have permission to access /panel/indexpl,php on this server.
Also, since your site uses WordPress, you can go to settings and change “http” part to “https” on both of your “WordPress Address” and “Site Address” fields.
