Radiodj-for-wordpress-0.7.0
https://classicradiofm.42web.io/
Is there a way to open the port 3306 so the RadioDJ Wordpress can work?
Port 3306 is usually for the database service which we do have support for it.
Instead of assuming a solution can you please post the actual error message so we can help you better?
This what the error I get in the RadioDJ plugin
Using mysqli client to connect
Connection took 10.01 seconds
Error connecting to RadioDJ database: Connection timed out
Please make sure that you are using correct IP address and port number.
Either your webhost is blocking outgoing MySQL connections or MySQL is not listening on given IP address and port.
OK so you are trying to connect to a remote database, unfortunately this is no longer supported.
