Protected Directories not working?
mk-drones.infinityfree.io
No error, just not working
I have used the Protected Directories feature but it does not seem to actuallly protect the directory i aimed it towards
Edit: The login box only pops up if i refresh the page while in the protected folder
Because you’ve only shared little information it’s very hard for us to help you.
What protected directory have you setup? What are you expecting the function to do, and what makes you believe that the current setup is not working?
The protected directories feature only show’s up on page load. So if you already had the page loaded or cached before setting up the protection, it wouldn’t show up to you refreshed
Is the protected directory filled with fully static content? If so, you may just be seeing the cached version stored inside your browser, without actually going to the server meaning you don’t run into the authentication yet.
I would have checked it for you, but it seems you’ve already removed the domain and deactivated the account.
