Problems with NamelessMC
Hello. I have a webpage for a Minecraft server I plan to open some time in the future. For the web page I use a web software called NamelessMC. This software can also communicate with a plugin installed on the Minecraft server, which is hosted somewhere else. However, I have a problem: The plugin throws an exception due to receiving a malformed JSON from the website it is communicating with. I talked to the NamelessMC devs about this and said this was due to a DDoS protection system being used. Does InfinityFree use any system that can cause webpages to send a malformed JSON?
Any help is appreciated
I think the NamelessMC devs are correct here. I do think the reason it doesn’t work is because of this security system:
https://infinityfree.net/support/javascript-error-using-api-or-mobile-android-app/
