Hello!
I can’t to login in the roundcube webmail. Page don’t loading.
How I can to solve this problem?
Best regards, FORT15.
I can tell that roundcube is loading fine for me and login working too without any problems. The website was down for a few days and maybe you should wait a while to load it, if the problem is loading the website. You still better to provide at least something about error that you’re facing.
I just going to cpanel, and go to the login webmail, first time page is loads for a very long time, and then gives an error connecting to the server.
I believe this issue should get resolved by itself soon for you, but for now you can try to ping the roundcube’s IP address(185.27.132.238) to check if it’s not your ISP/firewall issue
Thank you! Now all is working.
