My website has slow speed and failed the response efficiency test even though the page only has 49k of data. I noticed the delay in response and page loading, which didn’t open completely, requiring reconnection through the browser (the only infographic on the page is not shown and a broken link signal appears). For the page to load correctly, it is necessary to repeatedly reconnect for the page to load correctly. I noticed that a response from the host appeared in the address bar: canonical address + “/?i=1”.
Searching the internet, I found the answer: it’s a filter that the host has and, in addition to slowing down the connection speed significantly, it prevents graphic elements from forming correctly on the first attempt to access any page. Does anyone know how to disable this filter?
Slow connection speed (page disapproved by Google), poor browser response, indications of malfunctioning filters. (com.br/?i=). Page data volume: 49k.
How to work around the problem?
Please understand that this is an English forum, and all posts must be in English even if you just translate it with a translator would be OK. I’ve translated the post for you, but any further posts that are not in English might be flagged and deleted without prior notice.
Your website is loading pretty fast for me.
You cannot disable the security system.
The hosting servers are located in UK so speed may differ depending on where you are and whether or not you have a good connection. I would like to make it very clear that the security system is very unlikely the cause of what you are experiencing right now. The page loads both fast and correct on first try for me.
That is to say, I don’t think you understand how to tell the actual size of a webpage. Your webpage is definitely not 49k in size, because that is just the HTML file alone. A size of the webpage is everything in total, including the images, JavaScripts, stylesheets, etc, and your website clocks in at a whopping 2.9 MB which is huge.
I just did a website speed test and the page was fully rendered in just over 400 ms. And most of that time is taken up by the initial request being in the Blocked state for 250 ms, which is just the speed test tool waiting for stuff.
And that’s for 1.7 MB of content, not 49 kB.
When you run the same test from Brazil, it’s a lot slower of course (Pingdom reports almost 2.5 seconds), but the test from London proves that that’s caused exclusively by the distance, not the hosting itself being slow.
Also, for Google to reject your website (for what exactly?), it must be EXTREMELY slow. Much slower than any of these tests show.
