Hello, how are you?
So, I’m trying to point my domain “.com.br” to infinityfree, but it always appears that the given nameservers have no authority over the domain.
How is it possible to resolve?
Regards.
Welcome!
Unfortunately, I don’t think you will be able to host your domain with us because of this:
Thanks!
Well, quite disheartening!
There should be other ways to verify domain ownership. Type A and CNAME notes, for example.
You can use those after you set nameservers. Because of the way the system was created, it requires nameservers to be set.
Only a select few domains are affected by this, so you can always get a different one (Like .com or .net)
