Problems connecting to FTP (using FileZilla)
epiz_32357985
So for two days back to back, I cannot connect to the FTP server… It worked fine before until now… Using the same login as before, is FTP really down this long?
Can you share the full log from FileZilla?
And FTP is working fine for me, try clearing your computers dns cache, restarting your router, and/or using a different network, such as cellular with a hotspot to your pc.
Thank you for the educational reply
I flushed my dns cache and restarted the router
Here is my FileZilla log
Trace:	CControlSocket::SendNextCommand()
Trace:	CFtpLogonOpData::Send() in state 0
Status:	Resolving address of ftpupload.net
Status:	Connection attempt failed with "EAI_NONAME - Neither nodename nor servname provided, or not known".
Trace:	CRealControlSocket::OnSocketError(11001)
Trace:	CRealControlSocket::DoClose(66)
Trace:	CControlSocket::DoClose(66)
Trace:	CFtpControlSocket::ResetOperation(66)
Trace:	CControlSocket::ResetOperation(66)
Trace:	CFtpLogonOpData::Reset(66) in state 1
Issue is likely on your end. Can you try using other network(s)?
That’s interesting, it doesn’t seem to be able to resolve the FTP hostname.
Could you please try using the FTP hostname ftp.epizy.com or the FTP server IP address 185.27.134.11 instead? You may get an SSL warning because the certificate on the server is for ftpupload.net, but you can just accept that certificate and connect.
Thank you everyone for your replies. Today morning everything magically started working… I assume my million late-night DNS flushes and router restarts worked ¯_(ツ)_/¯
@Admin Thank you for alternative hostnames, if I have this problem in the future I will keep in mind
