I have a problem with my WordPress website, what happens is that when I want to modify the Widgets of my Astra theme, I get the following error “An error occurred. You are probably offline.” I already deactivated plugins, I even tried different themes but nothing, locally you can change and modify the widgets without problem.
You need to install plugin called classic widget, after you edited it, you can delete it later try it and tell if it fixed for you
