Problem with wordpress admin
I just installed wordpress, the site itself works, but when i try to access the admin panel, i get a redirect loop and the error ‘this page sent too many redirects’ from chrome. I tried reinstalling, please help.
My username is: epiz_25702517
What is your URL?
Https://Bitbank.digital/wp-admin
And i do not have ANY .htaccess file, n’either in the wordpress directory, neither in the main one
Okay, probably this is misconfigured:
Both of the bottom values need to be https:// so that your site and the admin section will function properly.
As you do not have access to the admin area, edit these lines in the wp-config.php file:
define('WP_HOME','https://example.com'); define('WP_SITEURL','https://example.com');
And i cant find those 2 lines in the wp-config file, is it a problem that i have no .htaccess file?
I still cant find it
It should be there, you probably didn’t read the lines carefully.
Try changing it on your MySQL database instead.
  1. Go to Control Panel
  2. Go to phpMyAdmin and choose what database you want to edit.
  3. Go to wp_options (will depend on your prefix ex: wpxf_options, wpgr_options).
  4. Edit the Site URL and Homepage URL just like what @Magnus told you. Change your URL prefix from http to https
I fixed it. I just reinstalled WP bur this time chose http:// instead of https://, which prevents the redirect loop.
