Problem with the nameserver setting
www.nocx.it
I try to set the following nameserver on Aruba server:
But the system was not able to complete the setting.
The Aruba support reply the following error:
Nameservers list [ns1.infinityfree.com., ns2.infinityfree.com.] different from NS Records: [ns1.infinityfree.com., ns2.infinityfree.com., ns1.byet.org., ns2.byet.org., ns3.byet.org., ns4.byet.org., ns5.byet.org.] Nameservers list [ns1.infinityfree.com., ns2.infinityfree.com.] different from NS Records: [ns1.infinityfree.com., ns2.infinityfree.com., ns1.byet.org., ns2.byet.org., ns3.byet.org., ns4.byet.org., ns5.byet.org.] Number of NS records must be between 2 and 6. Found: 7 Number of NS records must be between 2 and 6. Found: 7
In dettails the following checks wasn’t approved:
  • NSCountTest: the NS record should be between 2 and 6
  • NSCompareTest: the compare test failed
Please do this
Please note that these IP addresses are not correct.
Alternatively, you could try setting all of the following nameservers:
Although the NSCountTest error says you should not have more than 6 nameservers (which is odd, the official rules of DNS say you can have up to 10 nameservers).
