When I create a database with the wordpress extension, when importing my database, it is damaged, it redirects me to the wordpress installer, the default table prefix when created with the wordpress cpanel is “wpou” when deleting and Replace with my imported database, everything is damaged! What can I do?
What do you mean by creating a database with the WordPress extension? You can only create a database through our control panel. You can populate the database using our phpMyAdmin installation, or by PHP scripts running on your account.
If you’re using a plugin to import an existing website, then don’t. These plugins are extremely error prone and break websites more often than not in my experience. If you’re looking to migrate an existing website, please follow our official migration guide instead:
