Hello, I have a problem with addind a Cloudflare SSL, it says my domain is not registered, but it is, in cloudflare I can register with any problem, is there a different way to add SSL without adding via Cpanel? Thanks
Hello there,
Nope there is no other way, and also Cloudflare’s SSL certificates does not register your domain name as the common name of the SSL certificate since it’s supposed to be a shared/universal SSL certificate therefore the Control Panel does not allow you to add it unless if the common name of the certificate is registered to your domain that it will know that the SSL certificate you want to install is yours.
You can use cloudflare flexible ssl.
Who or what is “it” that says this?
