Problem with SSL
My website URL is: formasdesign.com
What I’m seeing is: problem with ssl certificate:
when i try to download this free ssl certificate, after uploading 2 verification files to my site, i get this message. please help. thanks in advance.
Domain “formas design” challenge3 failed. Response from “https://acme-v02.api.letsencrypt.org/acme/chall-v3/3067104203/jUsySw” was:
Warning: Your verification URL is not returning the correct contents to our verification servers. The URL looks like it is blocking bots and which inadvertently blocks our servers from receiving the correct content. Contact your host, a professional developer or admin for further help with fixing it.
Error: Invalid response from http:// formas design (can’t put more than 2 urls in this post) /.well-known/acme-challenge/HP2ZCz1YJVNl1x6k4Dxs9U6zfgA9Yv2WeiQYziFg_RA [185.27.134.223]: “<script type="text/javascript" src="/aes.js" >function toNumbers(d){var e=;d.replace(/(..)/g,func”
Full Error: { “type”: “http-01”, “status”: “invalid”, “error”: { “type”: “urn:ietf:params:acme:error:unauthorized”, “detail”: “Invalid response from http:// formas design /.well-known/acme-challenge/HP2ZCz1YJVNl1x6k4Dxs9U6zfgA9Yv2WeiQYziFg_RA [185.27.134.223]: "\u003chtml\u003e\u003cbody\u003e\u003cscript type=\"text/javascript\" src=\"/aes.js\" \u003e\u003c/script\u003e\u003cscript\u003efunction toNumbers(d){var e=;d.replace(/(..)/g,func"”, “status”: 403 }
done in previous step.
I’m using this software: wordpress
Additional information:
Infinity Free bot protection script blocks sslforfree.com or any file verification method. Consider using the free SSL provided in the client area. Or use Cloudflare. But these two methods won’t work with subdomains unless you use Cloudflare enterprise.
thanks for your answer. how do i configure the free ssl provided?
https://infinityfree.net/support/how-to-create-cname-records-for-free-ssl/
https://infinityfree.net/support/how-to-install-an-ssl-certificate/
https://infinityfree.net/support/how-to-force-all-traffic-to-https/
