Problem with setting WooPayments
When I try to set up payments I get the following notification:
Please contact your host for assistance with investigating this issue further.
There was a problem connecting this site to WordPress.com: “The Jetpack server was unable to communicate with your site https://varona.free.nf [IXR -32300: transport error: http_request_failed cURL error 52: Empty reply from server]”
Is it possible to fix it?
Thanks
It’s running into this:
Jetpack is also not recommended here. It’s a very heavy plugin and can lead you to suspensions. Plus, if you really need parts of its functionality, there are probably better plugins to use.
