Problem with my domain
I have problem with domain i have write name servers and make everything will and my site still down can anyone help me please?
Did you add it to your site?
Or what’s your site url?
Can you please fill in the topic template so we can help you effectively?
<!-- Please answer the questions below so we can help you quickly and effectively. -->
<!-- Make sure to answer all the questions below, or people may not be able to help you effectively, or at all! -->
**My website URL is:**
<!-- Please post the full website URL (or just the domain name, if it doesn't affect a web page) on which you get this issue. -->
**What I'm seeing is:**
<!-- Please describe what you SEE. For example, you could write steps to reproduce, copy-paste error messages or error logs, or share screenshots. -->
<!-- Please don't write "I can't do X" or "X is not working". Describe what you can see, not what you think this means. -->
**I'm using this software:**
<!-- Please say which software you are using which is relevant for the issue. Like a CMS, website builder, FTP client, file manager or web browser. -->
**Additional information:**
<!-- Write any other relevant information here. -->
**My website URL is: http://aternal.ga**
**What I'm seeing is:my domain still down after i write name servers**
**I'm using this software: MyBB Forum**
Your domain is also pointing to ns3.epizy.com, ns4.epizy.com and ns5.epizy.com, which don’t exist and will not serve your website. Please remove the last three nameservers from your domain registrar’s nameservers management panel, and then wait until they have propagated.
ok i have delete last 3 name servers…
for me it shows 403 forbidden. Time to upload your files in htdocs inside aternal.ga folder :slight_smile:
I already uploaded it but i can’t see my domain in “addon domains” in controll panel , And we i try to ad my domain keep offer me that I should contact support…
what error do you receive while adding?
I don’t know the exact error code, but it ends with “Please contact support”. It’s written in a somehow weird English right at the end of his post.
Your domain now points to Cloudflare’s nameservers, and to add the domain into your account you MUST point it back to ns1.epizy.com and ns2.epizy.com, then add it back, and then you are free to change them to Cloudflare’s nameservers whenever you want. After that, you should also point your domain’s DNS to the correct IP address, and this article should help you find the IP address of your account.
I have change name servers and i have my ip address put idk where i must put it, can you help me?
So, you should delete all existing records and add, on the DNS section of the Cloudflare dashboard for your domain, two A records, one with name @ and one with name www, that have as target the IP you got from the instructions present on KB article. To add two A records click on the “Add Record” button, then insert what I said as A records. After that, to have the changes applied to your domain on Cloudflare, you can now change the nameservers to Cloudflare’s ones, and after that you can now have Cloudflare enabled while still being able to visit your website.
I done everything but my site still down, can i find any way to make it automatically?
Or can i send my account details for you and you make it for me, please?
I can’t make your website online for you. Cloudflare’s nameservers need to have valid DNS records in order for your website to work fine, and the instructions I posted and will quote here:
should work fine.
I have done everything, but cloudflare still requires mx record from me…
Cloudflare doesn’t require MX records to work properly. It only suggests to add a MX record to receive emails, but doesn’t require it. So, if you don’t have email accounts for your domain, I suggest to ignore it.
Ok, i have done everything but when i try to park my domain keep saying “Error #93681767457 Please contact support.”
Change your domain name servers to ns1.epizy.com and ns2.epizy.com then Add your Domain.
After that, change the nameservers to cloudflare one again.
By “park my domain” do you mean adding it as a Parked Domain? Because if so, the reason you can’t do that is because your account doesn’t have any domain name you can park the domain on.
If you want to add a custom domain and don’t have an existing domain to park it on, you can add it through the Addon Domains section instead. Or you can deactivate this account and create a new account with your domain name.
