librojanasincantu.it
When I change my nameservers to ns1.epizy.com , ns2.epizy.com , etc. the Italian registry does not validate the change
If I perform a “dig” on the nameservers for the domain, I get an empty response:
dig @ns1.epizy.com librojanasincantu.it
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.68.rc1.el6_10.8 <<>> @ns1.epizy.com librojanasincantu.it
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 36154
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; WARNING: recursion requested but not available
;; QUESTION SECTION:
;librojanasincantu.it. IN A
;; Query time: 54 msec
;; SERVER: 185.27.134.7#53(185.27.134.7)
;; WHEN: Fri Jan 15 12:02:21 2021
;; MSG SIZE rcvd: 38
Can you help me fix this? Maybe I have to set different NS?
Kind regards
Hi Soundar,
That’s what I’m trying to do. I’m trying to point the domain to InfinityFree nameservers but the change fails because the .it Registry check says there’s something wrong with the nameservers.
Could you please check that the domain librojanasincantu.it is correctly configured with these nameservers?
ns1.epizy.com
ns2.epizy.com
ns3.epizy.com
ns4.epizy.com
It it’s not ok, can you tell me if there’s something I can do within my account or please provide me alternate nameservers?
Thank you
Kind regards
Re-purchase domain that’s not with these 3 TLD’s? Or try another hosting
Hi,
I confirm it’s not working either with ns1,epizy,com / ns2,epizy,com nor ns1,byet,org / ns2,byet,org (edited periods with commas because of forum limitations)
You can check here: https://dns-check.nic.it/
I wonder why is it so difficult to create a working DNS zone on two nameservers?
Thank you
Kind regards
Admin
January 15, 2021, 4:38pm
8
Did you read the information provided by @anon77371365 and @FlutterHoney ?
Both refer to the same article, which both have a very clear conclusion:
You cannot host .it domains with us at this time.
system
Closed
January 30, 2021, 4:38pm
9
