my site is not working IP: 185.27.134.34 | www.edgardonocetti.com.ar
Hi and welcome to the forum! This doesn’t seem to be the problem with your IP, as your website loads up. Perhaps your WordPress installation is corrupted:
WordPress frequently releases updates, which you can install through WordPress’ admin interface. Usually, this works without a hitch. But with some (big) upgrades, the upgrade fails half way and leaves you with a broken website.
Fortunately, you can still fix your website without any data loss, and this article tells you how to do that.
Download a fresh copy of WordPress
First of all, you will need to download a fresh copy of WordPress. You can download this from the official WordPress website…
And take note of this as well:
Do you often see this on your WordPress website?
[image]
If so you may need to change some of the installation settings.
Installing WordPress
For
Fresh Installation
Make sure you are using the following settings when using Softaculous Install
[image]
Existing Installation
You can access your existing installation via
[image]
Followed by
[image]
Make sure these are the settings used
[image]
On the WordPress config
To play safe, add this line to the wp-config.php
[image]
