gruposabemas.wuaze.com
The domain is not pointing to the server.
Hi,
I’m trying to install moodle with softaculous in my site. However, I receive this message. It tells me that the domain is not pointing to the server. The domain I’m using is .wuaze.com, which is a free InfinityFree domain. How can I fix that?
KangJL
November 25, 2023, 2:18pm
2
chemamartinez:
How can I fix that?
You can’t. You can only wait it out
Hi,
Because of what you have said, it happens because it is a new website? For how long should I wait?
You currently have WordPress installed, presumably from Softaculous. I would delete the WP install before installing moodle.
HI,
I’m stalling Moodle in the root /moodle, and wordpress is in the principal page. Should I unsinstall it?
Admin
November 25, 2023, 3:54pm
6
The error is odd, because your domain is pointing to our servers, and there is nothing blocking access. You shouldn’t see this error?
Could you please check if you only get this error with Moodle or also with other software?
Hi, I’ve tried again after a few hours and I can install Moodle. Thanks a lot to all of you!
system
Closed
December 2, 2023, 5:07pm
8
