epiz_33694559
URL to with does apply
Description of problem
After uploading the files, I had renamed the index.html file (with was displayed correctly) to index.php. After that, I see only a blank page
epiz_33694559
I see a 500 error on your site:
Strange, I don’t have any .htaccess file and there is no much php code added to it.
Cnontent of the index.php:
<?php
if (isset($lang)) { require_once("i18n/" . $lang . ".inc.php"); }
else { require_once("i18n/en.inc.php" }
... some html content ...
<h1>
<a href = "index.php">
<?php echo $lang["home"]; ?>
</a>
</h1>
... rest of the html, without more php code ...
Ah, I forgot to mention, none message is displaying to me
Can you please turn on display errors like suggested in the article? Also, $lang is also going to be false, and you are probably going to get a warning about it being undefined as well.
Thanks. It had helped
