This btn should redirect to other page but instead it redirect blank page.
I don’t understand, in my XAMPP work.
Link to home page:http://pcgsm.great-site.net/index.html
I noticed you’re using capital letters in the filename it uses, submitedADesktop.php. Is it possible that one or more letters isn’t the correct casing?
Also, it’s generally advised to use all lowercase filenames in web development, since most web hosting providers (including InfinityFree) run Linux on their servers; File names are case sensitive on Linux.
thanks for advice.I will try this.
