I am stuck on request to get an ssl certificate for my domain (suichiyuri.online) I have followed the steps of a tutorial I found, but I get an error
Also I have already generated the key, and I also uploaded it (https://cpanel.epizy.com/panel/indexpl.php?option=sslconfigure&domain_name=suichiyuri.online )
I am very lost in this, I hope your help. Thank you
a, You can’t get the SSL until you have added the record for _acme-challenge.suichiyuri.online , which as dig says;
_acme-challenge.suichiyuri.online. 21599 IN CNAME 11776.BODIS.COM .
Which is the default CNAME holding page, so you may need to check you have added the record in the VPanel
So the 2 “acme” should be added? I thought it was only 1, with www or without www. I’m going to add right now
Yes, both cname records need to be added.
katufo
July 12, 2020, 7:57am
5
Then, you will need to wait for an hour to get your ssl certificate, then copy the certificate and private key and paste it into SSL/TLS.
Thank you all very much, the ssl certificate is already working. I only have a question, how can I make those who enter my page through “http” be redirected to “https”
In .htaccess enter (In the htdocs for your domain)
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301,NE]
katufo
July 12, 2020, 6:45pm
8
If you’re using wordpress, install a plugin called “Really Simple SSL”, this will overwrite and force all http request or visitors to HTTPS.
Thank you very much, I have already been able to redirect you from http to https
