403 Forbidden
I am new in this website hosting, i have uploaded all the files and create the index.php as htdocs/leave_system/index.php.
please help to resolve the problem
You can’t put a index file inside of a folder like that. Main file should be inside of the htdocs folder.
Put your index.php file in the htdocs folder. It should fix the issue
Hi and welcome to the forum! If you want your website to show up as main page, please move the files outside the folder you uploaded/created while still keeping them on your htdocs folder, else it would be accessible on yourdomain/folderyoucreated/. Also, when I tried to access the actual index inside that folder, I get a HTTP ERROR 500:
When trying to access your website, you may see a page which returns the status code “500”. In Google Chrome, you’ll see a page with the error code HTTP ERROR 500.
There are typically two reasons which can cause this error:
The PHP code has crashed.
The .htaccess file contains invalid rules.
Here are some things you can try to debug and fix this.
Fixing crashing PHP code
A HTTP ERROR 500 simply tells you that the PHP code has crashed, but gives no information as to why it has crashed.
Gett…
Warning : require_once(classes/DBConnection.php): Failed to open stream: No such file or directory in /home/vol1_7/infinityfree.com/if0_35744353/htdocs/config.php on line 8
Fatal error : Uncaught Error: Failed opening required ‘classes/DBConnection.php’ (include_path=‘.:/usr/share/pear/’) in /home/vol1_7/infinityfree.com/if0_35744353/htdocs/config.php:8 Stack trace: #0 /home/vol1_7/infinityfree.com/if0_35744353/htdocs/index.php(1): require_once() #1 {main} thrown in /home/vol1_7/infinityfree.com/if0_35744353/htdocs/config.php on line 8
getting this error please help me resolve…i am new in this field
i have resolved the warning error but how to resolve fatal error please support
You’ll have to make sure you also uploaded the remaining files on the htdocs folder. Only creating an index.php isn’t enough.
i have done the same but still getting the fatal error
Oxy
January 9, 2024, 6:01pm
10
Fatal error : Uncaught Error: Undefined constant “sql105” in /home/vol1_7/infinityfree.com/if0_35744353/htdocs/classes/SystemSettings.php:136 Stack trace: #0 /home/vol1_7/infinityfree.com/if0_35744353/htdocs/config.php(9): require_once() #1 /home/vol1_7/infinityfree.com/if0_35744353/htdocs/index.php(1): require_once(‘/home/vol1_7/in…’) #2 {main} thrown in /home/vol1_7/infinityfree.com/if0_35744353/htdocs/classes/SystemSettings.php on line 136
go to this location /classes/SystemSettings.php and copy the source of this file
paste the code on the forum, but first hide all sensitive data or write something like paswswwddd, uuusername instead of real data
and then select it all and choose code formatting
last = publish a post
<?php
if(!class_exists('DBConnection')){
require_once('../config.php');
require_once('DBConnection.php');
class SystemSettings extends DBConnection{
public function __construct(){
parent::__construct();
function check_connection(){
return($this->conn);
function load_system_info(){
// if(!isset($_SESSION['system_info'])){
$sql = "SELECT * FROM system_info";
$qry = $this->conn->query($sql);
while($row = $qry->fetch_assoc()){
$_SESSION['system_info'][$row['meta_field']] = $row['meta_value'];
function update_system_info(){
if(isset($_SESSION['system_info'][$row['meta_field']]))unset($_SESSION['system_info'][$row['meta_field']]);
return true;
function update_settings_info(){
$data = "";
foreach ($_POST as $key => $value) {
if(!in_array($key,array("about_us","privacy_policy")))
if(isset($_SESSION['system_info'][$key])){
$value = str_replace("'", "'", $value);
$qry = $this->conn->query("UPDATE system_info set meta_value = '{$value}' where meta_field = '{$key}' ");
}else{
$qry = $this->conn->query("INSERT into system_info set meta_value = '{$value}', meta_field = '{$key}' ");
if(isset($_POST['about_us'])){
file_put_contents('../about.html',$_POST['about_us']);
if(isset($_POST['welcome_content'])){
file_put_contents('../welcome_content.html',$_POST['welcome_content']);
if(isset($_FILES['img']) && $_FILES['img']['tmp_name'] != ''){
$fname = 'uploads/'.strtotime(date('y-m-d H:i')).'_'.$_FILES['img']['name'];
$move = move_uploaded_file($_FILES['img']['tmp_name'],'../'. $fname);
if(isset($_SESSION['system_info']['logo'])){
$qry = $this->conn->query("UPDATE system_info set meta_value = '{$fname}' where meta_field = 'logo' ");
if(is_file('../'.$_SESSION['system_info']['logo'])) unlink('../'.$_SESSION['system_info']['logo']);
}else{
$qry = $this->conn->query("INSERT into system_info set meta_value = '{$fname}',meta_field = 'logo' ");
if(isset($_FILES['cover']) && $_FILES['cover']['tmp_name'] != ''){
$fname = 'uploads/'.strtotime(date('y-m-d H:i')).'_'.$_FILES['cover']['name'];
$move = move_uploaded_file($_FILES['cover']['tmp_name'],'../'. $fname);
if(isset($_SESSION['system_info']['cover'])){
$qry = $this->conn->query("UPDATE system_info set meta_value = '{$fname}' where meta_field = 'cover' ");
if(is_file('../'.$_SESSION['system_info']['cover'])) unlink('../'.$_SESSION['system_info']['cover']);
}else{
$qry = $this->conn->query("INSERT into system_info set meta_value = '{$fname}',meta_field = 'cover' ");
$update = $this->update_system_info();
$flash = $this->set_flashdata('success','System Info Successfully Updated.');
if($update && $flash){
// var_dump($_SESSION);
return true;
function set_userdata($field='',$value=''){
if(!empty($field) && !empty($value)){
$_SESSION['userdata'][$field]= $value;
function userdata($field = ''){
if(!empty($field)){
if(isset($_SESSION['userdata'][$field]))
return $_SESSION['userdata'][$field];
else
return null;
}else{
return false;
function set_flashdata($flash='',$value=''){
if(!empty($flash) && !empty($value)){
$_SESSION['flashdata'][$flash]= $value;
return true;
function chk_flashdata($flash = ''){
if(isset($_SESSION['flashdata'][$flash])){
return true;
}else{
return false;
function flashdata($flash = ''){
if(!empty($flash)){
$_tmp = $_SESSION['flashdata'][$flash];
unset($_SESSION['flashdata']);
return $_tmp;
}else{
return false;
function sess_des(){
if(isset($_SESSION['userdata'])){
unset($_SESSION['userdata']);
return true;
return true;
function info($field=''){
if(!empty($field)){
if(isset($_SESSION['system_info'][$field]))
return $_SESSION['system_info'][$field];
else
return false;
}else{
return false;
function set_info($field='',$value=''){
$_SESSION['system_info'][$field] = $value;
$_settings = new SystemSettings();
$_settings->load_system_info();
$action = !isset($_GET['f']) ? 'none' : strtolower($_GET['f']);
$sysset = new SystemSettings();
switch ($action) {
case 'update_settings':
echo $sysset->update_settings_info();
break;
default:
// echo $sysset->index();
break;
I think you need to check your DBConnection.php file. There’s nothing wrong with the code you provided. It’s either caused by DBConnection.php or config.php
Oxy
January 9, 2024, 6:17pm
13
It looks like you have all the paths mixed up and in the wrong places
or incomplete upload
Please upload everything again and pay attention that all the files are where they should be
This way we just jump from one problem to another, and I think it’s simpler to upload everything again
And tell us what your website actually does?
what is it about? I’m asking in the sense that maybe you don’t try to fix it if it’s an API for mobile apps and the like because this is hosting exclusively for websites
<?php
if(!defined('DB_SERVER')){
require_once("../initialize.php");
class DBConnection{
private $host = DB_SERVER;
private $username = DB_USERNAME;
private $password = DB_PASSWORD;
private $database = DB_NAME;
public $conn;
if (!isset($this->conn)) {
$this->conn = new mysqli($this->host, $this->username, $this->password, $this->database);
if (!$this->conn) {
echo 'Cannot connect to database server';
exit;
public function __destruct(){
$this->conn->close();
This code is not responsible for the error it is causing. Like @Oxy mentioned you are going to have to reupload every file with the correct order. We can’t be exactly sure what’s causing the issue since there are too many files included in your project. But anyway, check your project file for sql105 constant.
my database host name is sql105.infinityfree.com other than this i have not found sql105 anywhere…is this creating the issue
No it’s not. The error you are seeing is caused because PHP trying to use the constant sql105 , but it cannot find a definition for it.
Are you certain you’ve provided the whole code of the SystemSettings.php file? Because the error is causing inside of that file.
I’ve also checked the stack traces and the OP might need to check either config.php or initialize.php placed both on the htdocs folder.
@rahulkast , can you please also share the contents of either those two files I’ve listed to see where is the problem?
here is the config.php code
<?php
ob_start();
ini_set('date.timezone','Asia/Manila');
date_default_timezone_set('Asia/Manila');
session_start();
require_once('initialize.php');
require_once('classes/DBConnection.php');
require_once('classes/SystemSettings.php');
$db = new DBConnection;
$conn = $db->conn;
function redirect($url=''){
if(!empty($url))
echo '<script>location.href="'.base_url .$url.'"</script>';
function validate_image($file){
if(!empty($file)){
// exit;
if(is_file(base_app.$file)){
return base_url.$file;
}else{
return base_url.'dist/img/no-image-available.png';
}else{
function isMobileDevice(){
$aMobileUA = array(
'/iphone/i' => 'iPhone',
'/ipod/i' => 'iPod',
'/ipad/i' => 'iPad',
'/android/i' => 'Android',
'/blackberry/i' => 'BlackBerry',
'/webos/i' => 'Mobile'
//Return true if Mobile User Agent is detected
foreach($aMobileUA as $sMobileKey => $sMobileOS){
if(preg_match($sMobileKey, $_SERVER['HTTP_USER_AGENT'])){
return true;
//Otherwise return false..
return false;
ob_end_flush();
