I ran into this PHP issue while doing the installation.
PHP-CLI 7.3
or higher is required.
PHP escapeshellarg() function
The PHP escapeshellarg()
function must be enabled.
The PHP exec()
please help me fix this problem i don’t know how to attach jpeg files here
http://doska.rf.gd/install/system_compatibility
Welcome! PHP command line functions are not supported on free hosting.
Hello, thanks for your answer. Please tell me how to edit files on the server?
Thanks for your answer. I do just that, but the problems remain such a feeling that it’s impossible here at all. I can’t run a single PHP script that I could do on other hostings here, sorry
What do you mean? Besides the CLI functions, what is preventing the script from working?
I can’t understand yet, maybe I entered the wrong mysql data Although I have already tried all the options
http://test1000.rf.gd/dashboard/Auth
the script is installed True, all folders are present, this is displayed in the following link, but the login to the script control panel does not exit
unfortunately we couldn’t wait for help, nevertheless thanks for being in touch))
$db['default'] = array(
'dsn' => '',
'hostname' => 'localhost',
'username' => 'epiz_30741517_webview2',
'password' => 'XYXYXY',
'database' => 'epiz_30741517_webview2',
'dbdriver' => 'mysqli',
'dbprefix' => '',
'pconnect' => FALSE,
'db_debug' => (ENVIRONMENT !== 'production'),
'cache_on' => FALSE,
'cachedir' => '',
'char_set' => 'utf8',
'dbcollat' => 'utf8_general_ci',
'swap_pre' => '',
'encrypt' => FALSE,
'compress' => FALSE,
'stricton' => FALSE,
'failover' => array(),
'save_queries' => TRUE
Oxy
April 21, 2023, 2:29pm
11
Not localhost !
but look at which database server is listed in the client area
when you choose your hosting acc
then you have this as a side menu on the left side
click here and read
Many websites use MySQL databases to store information and settings. However, there are some reasons why the connection to the database may fail. This article describes some commonly seen error messages when connecting to a database, as well as some general tips to keep in mind when setting up a database connection.
Common Error Messages
Using MySQL is great, but the error message returned if there is an issue logging in to your database can be quite confusing. Here are some commonly seen error…
Your username is also wrong !
And do not publish the password publicly !
I can’t figure out what database name to enter
Please see the information in the “MySQL Databses” section of the control panel for the database name.
Everything worked out! Thank you
system
Closed
April 30, 2023, 1:58pm
15
