Hello, i have my website xeratdragons.com but have error Google Console for Sitemap XML not found Error HTTP 404 and olther
This is Problem for CMS wordpress?
And I ask if you can insert the SEO feature in order to be able to manage it because unfortunately there are indexing problems on the site including also for the search engine which is difficult to be found,
Every time when I enter my site on wordpress I get this error # Error establishing a database connection
This either means that the username and password information in your wp-config.php file is incorrect or that contact with the database server at sql104.byetcluster.com could not be established. This could mean your host’s database server is down.
Better if you left NS from Cloudflare and deleted the others
because I assume that your site wants to use HTTPS
and as far as I can see, you have a self-sign certificate probably for running Cloudflare Full
so it’s better for you to have all your traffic go through Cloudflare
