Problem Connecting Make.com to WordPress
Hello,
I’m trying to connect Make.com to my WordPress site on InfinityFree, but I keep getting a JSON error saying : "Function ‘get’ finished with error! Function ‘fixBOM’ finished with error!
Unexpected token ‘<’, “<bod” is not valid JSON "
I’ve disabled LiteSpeed Cache, adjusted Cloudflare settings, and tested my API, but the issue persists. Is InfinityFree blocking API requests? If so, is there a way to fix it?
Thanks for your help!
Yes, API requests are blocked on InfinityFree.
And no, there’s no way to disable it or bypass it. Premium hosting doesn’t have this limitation, but you won’t be able to use make.com’s automation services on InfinityFree I’m afriad.
Hello, and welcome to the InfinityFree Forum!
This is caused by our mandatory security system that can’t be disabled.
