gematria-decoder.42web.io
This site can’t be reached
Can’t Access phpmyadmin and softaculous. Tried using other browsers and OS and computer the problem still the same.
Both pages wouldn’t load at all
Hi,
Welcome to the forum. Try closing out all your tabs, go to InfinityFree.com and log into your account again. Then click on Control Panel and try again. I have found that sometimes my InfinityFree session expires while I am working on stuff in the background. When I try to access something in Control Panel I get an error. To fix it, I just close out all my open tabs, log into the Infinity Free site again (to start a new session), and then go back to Control Panel or File Manager and attempt my operation again.
If you get the error again (e.g. blank screen) – check to make sure you don’t have an ad-blocker which is blocking content on the page. Turn off any ad-blocker or VPN software just to check to see if it works.
