Hello, when i try to install PrestaShop 1.7.3.4 i get errors:
Install and enable the php_posix extension (used to colorize the CLI output).
Install and/or enable a PHP accelerator (highly recommended).
Set short_open_tag to off in php.ini*.
How to fix it?
Are these really errors you see, or just informational messages or recommendations? The three changes all seem minor cosmetic, performance and security tweaks, respectively. There is no reason why Prestashop shouldn’t be able to run without those changes.
@Simona said:
An error occurred during installation…
1: HTTP 500 - error -
Where do you see this error? On your website or somewhere else?
i upload files to ftp, created database and try install and that happened.
Yes i get that errors on my website when i try to install PrestaShop 1.7.3.4 and if i countinue i get this error: 1: HTTP 500 - error -
and installation stop. I tryed alot of times and same things happened.
But if i use Softaculous Apps Installer i dont get any errors and all working.
And i have next question. What “Inodes Used 100 % (37552 of 30019)” mean?
@Simona said:
And …
Your account was taken down because you have exceeded the usage limits for free hosting or because of abuse.
Your account was suspended because you have exceeded some of the limits, have you contacted support/opened a ticket?
If it was because you exceeded limits it will be reactivated in 24 hours.
