Preserving timestamps of uploads
Hello, support (and the forum)
I just got an account here, but cant figure out how to preserve uploaded files timestamps (attributes). Tryed both: ftp and cpanel tools
Please, advise, since this is quite an issue.
ps: is there a ways to upload ,besides quotted above tools? Like via ssh, or others, maybe, to get desired result.
Thank you.
No
You probably want to download a desktop ftp client like filezilla. The steps after that depends on your ftp client, try to search for the correct steps.
Well, thats what iam doing - searching… (if search results r not ā€˜filtered’:-i) Desktop use isnt an option… &i dont see the way to ask a service tech. support here, besides this forum:-i
Use the ā€œpreserve timestampā€ feature
Note that ā€œdate modifiedā€ and ā€œdate createdā€ are also different. Make sure you are viewing the right one.
Thank you, but i am not using this godzilla/filezilla (brazilla:) , since i have only the mobile, and this pkg` alt for android - has a bad reputation.
I should be able to get the same result w/ other (android) ftp pkgs…, and/or command line ftp from termux… Not yet figured out how.
FileZilla is desktop-only software, it’s not for mobile.
Do you have a family member, friend, (or foe) whose computer you can borrow? Your local library or media center may have the software available as well.
The online file manager does not preserve timestamps, and I don’t know of any mobile FTP software that does either.
Alternatively, you can modify your site to not required the date as well.
Tnx again (4 advertizing FZ:) here is FZ mob. alt, btw:
https://play.google.com/store/apps/details?id=com.fanglz.android.filemanager but i dont try it :slight_smile: &No ā€˜friends’! Relying on self )(Chuch?He - ideas:) And am sure there must be a way… to preserve… fr. mobile , with command line FTP, at least (as i said).
Say no to Information-blockades &ads monopoly!)
