POST /reserve returns 403 Forbidden (OpenResty) when submitting reservation
https://mcst-gym-reservation.gt.tc
403 Forbidden
openresty
This happens after clicking Submit Reservation. The failed request is POST https://mcst-gym-reservation.gt.tc/reserve.
This is a Laravel reservation website. Pages load, and POST /reserve/edit-details works, but the final POST /reserve consistently returns 403.
The request uses multipart/form-data and is approximately 17 KB. It also fails with a simple one-page PDF and in Chrome Incognito.
The submission controller has a warning-level diagnostic log at its first line, but no corresponding entry appears after the failed submission. The account is active, and the displayed resource usage is below the limits.
Latest test: October 21, 2026, approximately 6:51 PM UTC+8.
Could you check whether a server security rule is rejecting this request and advise how to resolve it?
The 403 page you’re getting is a bare “403 Forbidden / openresty”, not the InfinityFree error page. Can you tell me exactly what the response looks like? In your browser’s network tab, check the response body and whether the request is redirected to an errors.infinityfree.net/errors/403/ address.
That would show whether the block comes from the hosting’s own 403 handling or from somewhere else, and I can’t tell which from what you’ve posted.
Also, does a POST to /reserve still fail if you submit it without the file attached? That would show whether the upload part of the request is what triggers it. Your PDF test suggests the file type isn’t the problem, but it doesn’t rule out the multipart body.
The knowledge base article on InfinityFree 403 errors says URLs containing the keywords “chat” or “includes” are blocked automatically. /reserve doesn’t contain either, but check whether the URL, or any route or file behind it, does.
The article is here:
I found no source saying a server security rule rejects this kind of POST, so I can’t say that’s the cause.
The failed POST returns 403 directly at:
The address stays on /reserve. No redirect to errors.infinityfree.net was observed. The response is a plain page displaying “403 Forbidden” and “openresty”.
We have not tested without an attachment because the form requires a PDF. Both the original PDF and a simple one-page test PDF produce the same failure.
Could a human volunteer or administrator advise how to investigate this further?
I’m not completely sure if it’s related, but be aware that POST requests right now are partially blocked to mitigate the impact of two critical PHP security vulnerabilities that were disclosed earlier today. We’re still waiting on upstream updates to properly fix it, so until then, some POST requests will be affected.
Here is the status page issue with more information about this.
