I tried to upload via filezilla and i couldn’t see the plugin in the plg ins section at all . So i did a reset to my site and tried again but still i get the same error… Any ideas? ty
InfinityFree limits the size of files to 10 mb, unfortunately Brizy’s package is more than 10 mb.
So as a workaround, you can manually download the plugin locally and extract it locally and upload them with the help of the article provided by @anon12237952
Can you please double check you’ve uploaded the right folder of the plugin to the right folder of your site?
In your website should be a folder cybermarkets.ml/htdocs/wp-content/plugins/. In there should be a folder with the name of your plugin brizy, and directly within that folder should be a file called brizy.php. If that’s not the case, then you didn’t upload the right files to the right location, and WordPress doesn’t identify the code as a plugin.
